- 13 Apr 2013
- Scunthorpe
Yeah deffo gonna try the Hind on the free trial
Now my university exams are done until October I can chill out and learn the F18 finally.
You head strap looks interesting for your Track IR. What is it and where did you get it..please![]()
I’m still very much learning so sticking to quick missions. I was able to try the SC on the main missions and it’s flipping awesome being catapulted off it!!You can use it the carrier on anymap i guess the mission maker didn't add it to quick mission.
Yeah, I am using the pro clip on what was an xbox360 headset lol.
It's perfect for the pro clip because it's so lightweight I don't even feel on my head most of the time.
And best of all the 360 headsets are very cheap
I used some fabric tape on the white end bit for some padding against the plastic.
This looks amazing!
Depends on a vehicle. For example the UH-1 Huey helicopter in the screenshot above you do not need to learn ANY switches to fly. Just set up your joystick and throttle axes, select "take off hot" - and you'll appear in a helicopter that is already started and ready to fly. Once airborne, no need for switches either, and the only important dial is the vertical speed (strictly vertical descent must no exceed about 10 feet per second or you'd risk getting into a vortex ring state. ).Agreed, almost photo realistic.
I gave DCS a brief look in VR and it utterly confused me roflmao, how many hours would you say it takes to learn the basics (dash ,controls, procedures etc) before attempting to pilot a vehicle ?
