You've disabled Tessellation so you'd need to re-enable it to get on the leaderboard.3960x @ 4.341ghz
6900 XT @ 203core / 2140mem
https://www.3dmark.com/spy/21125217
Had to disable SMT or all scores take a big hit.
Where is that? Driver or in the 3dmark menu? I haven't changed anything.You've disabled Tessellation so you'd need to re-enable it to get on the leaderboard.
Global graphics menu of Radeon Software. It should be set to AMD Optimized.Where is that? Driver or in the 3dmark menu? I haven't changed anything.
That's better, much better!How weird. It was already set so I ran it again - managed to break 21k with a couple of tweaks!
3960x @ 4.368ghz
6900 XT @ 2740core / 2140mem
21117 - https://www.3dmark.com/spy/21142929
don't feel brave enough to bump the memory speed higher than 9800MHz
based on the official 3DMark global graphics score leaderboard I'm 44th in the world with this graphics score and 1st place in the UK! Not bad for a fairly average overclocker
GPU: 6800XT @ 2465-2565Mhz/2150Mhz (17200)
CPU: 5900X @ PBO with -10 all core offset
AMD Driver: Adrenalin 21.5.1
Time Spy Score: 18971
Graphics Score: 19820 (painfully short of 20k but the chip just isn't a great clocker)
CPU Score: 15268
For the scoreboard you need to post the results link
Oops, noticed my sig needed redoing while posting and forgot to add it. Edited the original post with the link.
