- 15 Mar 2018
- Scotland
If its an ASUS, yes. Well, for the PPT, EDC and TDC limits. Under the Advanced AMD Overclocking section EDC and TDC are hard-limited at 190 and 160.
Have to use the AI tweaker section to set numbers higher for TDC and EDC.
Other than that I don't think so, just AMD bios jank where there is multiple sections that can do the same thing. The curve optimiser is under the advanced AMD section and that is the only place it exists. At least on ASUS boards.
Ryzen Master will tell you what your PPT, TDC and EDC values are.
I have the Asus Crosshair VIII hero and can confirm there are two complete seperate areas for setting curve optimiser and the limits, they look identical but they arent because i am getting different performance from setting this under "Advanced > AMD Overclocking > Precision Boost Overdrive" as opposed to "Extreme Tweaker > Precision Boost Overdrive".
Until this point i have been doing everything under the Extreme Tweaker menu, inlcuding the limits and curve optimiser and got improved multi core result after adjusting the limits. However after making the same adjustments (including Curve Optimiser) in the AMD Overclocking section the improvements are different again. For example, my CB multicore score had gone up by 1000 points from just over 28,000 to over 29,000. The core speed in the same test has gone from 4.325 after settling down to 4.45.
I also saw the maximum core frequency go up to 5Ghz on multiple cores when idling (info from HWinfo64) but thats where the good news end though, i am still not getting 5Ghz in any meaningful way in single core testing either in CB or in Games. I appreciate it wouldn't go to 5Ghz and stay there but its just not going there at all. I am currently redoing the dance with corecycler and my previous result (when set in AMD Overclocking) have caused a couple hard resets, therefore i am currently running with 0 on the best two cores -10 on the next 4 cores and -20 on everything else.
I still have fair bit to go but i am a little bit more hopeful i might actually get there now.
