Weird engine noise, please help
5 Jul 2021
UK
Hi, not sure if this is the place for this type of post but here it is anyway. Bought a used 2010 Kia Ceed 1.6 diesel a few weeks back and I've noticed an odd clacking noise when accelerating at low speeds. I've uploaded a video of the noise here, it's best heard near the end of the video. Sometimes this noise is very loud, other times it's not as such. It doesn't make this noise at all when idling, only under load and even then it doesn't happen all the time. Any ideas of what it might be?
OP
5 Jul 2021
UK
I've taken it to a local garage and they've said it's most likely due to dirty fuel injectors. No engine light and it still seems to get pretty good mpg (60+ on motorway) so I'm dubious of this. Definitely coming from the engine bay though.
19 Dec 2002
after you have driven it and open the bonnet is there any mist above the engine? i know theres probably a engine cover but maybe worth removing it and seeing if anything is damp around the injectors? maybe when warm the injector is blowing had similar when injector clamps started to get loose on wifes honda managed to catch it before it popped the injector she stated it got noiser in the weeks before she mentioned it but again no lack of power or anything. just a thought,
OP
5 Jul 2021
UK
Had a look under the engine cover around the injectors and there's no smoke or dampness. Maybe something else worth mentioning is the car seems to judder a bit when accelerating at low speeds when the engine isn't warm. Runs just fine after warming up
OP
5 Jul 2021
UK
I only use the car for a 50 mile commute which is entirely motorway driving. There’s 93000 miles on the odo and 1 previous owner, not sure what they used the car for. The clacking only happens sometimes at low speeds when accelerating, after I put my foot down it goes away and the car runs fine. I bought an OBD reader and the car isn’t sending any codes
Man of Honour
13 Oct 2006
Sounds like what my sister had but I can't remember what the code was - basically throttle regulation wasn't getting feedback or something.
16 Jan 2005
South Wales
ASM Car Sales
I guess my approach would be, ask them if they're willing to accept the bill if you were to go to Kia to get it checked out and they found a fault. If so, pay for Kia to do the diagnostic and go from there. If they come back and say it's fine then you've only lost a few quid, if there's a fault then you get it nipped in the bud by the dealer you bought from.
