Which tablet
2 Dec 2004
Under The Desk, Wales
In the market for a new tablet. Looking at the market i am not sure whether or not to go Apple or Android.
I used to have an ipad years ago. Have also had an Android tablet too.
Here is my short list:
Alldocube iplay 40
Or
Ipad Air (2020)
Quite a big difference in price between the two and spec. Dont mind either platform. Just want a decent tablet.
Depends what you really want from it. The Android tablet is going to be exactly what it is - a cheap Chinese tablet. Specs looks good but it is unlikely to get any updates or support.
iPad is what you'd expect too. A higher end device which will receive updates and support for a while.
If you're after a decent tablet then go for the iPad or explore other options in the Android market.
Right, ipad is the best way forward then.
2 things that hold me back a bit.
Price. £550 approx for the ipad Air
As normal, no sd on Apple products. Is it easy enough to use a USB pen drive with an ipad? To back up or take data from?
