Hi All
I've been having to open windows/put fan on next to me to not melt with the amount of hot air blown out the side of my 3090 card.
It's usually when playing prolonged periods of warzone for example.
Temps from gpu stay between 60-65 degrees which I'm sure is fine.. However when you put your hand out to feel the amount of hot air being pushed through it's quite incredible.
I'm in a fairly decent size room with decent ventilation but even so.. I can't believe how quickly it heats up the room.
Does anyone else find this?
