Don
Except that the F1A5 is much cheaper that the PS4, often to the tune of £60-80 per set.
If they're so close in performance...what need is there to consider the PS4 if I can get the same for much cheaper?
Longevity maybe?
Possibly, although from anecdotal posts scattered across forums it does appear that the F1A5 do match the wear rates of the PS4Longevity maybe?
You went for PS4S though didn't you?Because you often can't? When I got mine they were a total of £50 a set cheaper than the F1A5, which if I am honest is what swung the decision for me. There is often a cashback offer run through Michelin which makes further savings.
Let's imagine I need a tyre right now. In my rear tyre size on Camskill, I can buy either:
Goodyear Eagle F1 Asymmetric 5: £175.20
Michelin Pilot Sport 4: £178.35
The difference is negligible enough to be of no consequence to the decision. This is often the case.
Righto. 4 on the front 4S on the back then?No, because as I said a few posts above they are not available in my front tyre size.
So what was that massive argument a few weeks back about fitting PS4S?No, 4 all round as I don't like mixing tyres.
I said I would have fitted them if I could have, which I would.
Got them for my dad's 630d if that counts
Literally an argument over nothing
*shakes fist*That's why we're here isn't it?
I know they aren't normally the most popular (but I had to get them really due to the unusual size and runflat requirement), but the new P Zero PZ4 are very impressive. Loads more grip than the previous model P Zero.
How much tread do you have left/how old are they?15k in on my Pilot Super Sports on the M140i and they are starting to feel a little twitchy at times, will be changing then for PS4S come Autumn.
I ran the PS4S on my M3 for around 35k miles on the back, down to 2.2mm when I changed them, and honestly I couldn't tell the difference between brand new and nearly completely worn out! Really incredible tyres.15k in on my Pilot Super Sports on the M140i and they are starting to feel a little twitchy at times, will be changing then for PS4S come Autumn.
