Don
- 20 Oct 2002
- Oxfordshire / Bucks
nah, trying to resist buy any more a accessories !
Do you mean graphics preference in the oculus software or just graphics options in games?What Graphics preference settings are you all using for PC VR?
It had been a good few weeks since I last played some Project Cars 2 (had to reinstall) but was really impressed how well it looked.What Graphics preference settings are you all using for PC VR?
Wanting to venture into a VR world and from what I have watched / read so far it seems that the Quest 2 ticks most of the boxes in terms of value for the cost.
I see that one place is offering this as a bundle (256GB model) for £419 with the Elite headset. Albeit one years warranty. JL would want around £448 for the same package but with two years warranty.
Our intent is primarily to use it as a PCVR experience, not sure if the 256GB is a little OTT in that respect, for the extra storage, or might be actually useful....?
Not sure if we will use the standalone feature over that of a wireless PCVR experience, but then again up to a couple of weeks ago, after trying out a friends Playstation VR, we hadn't got a clue what VR could mean.
So..... Does a 256GB seem a little OTT for a primary PCVR usage and is the Elite headset worth buying from the start...?
Anything else to think about for the initial purchase..?
Thanks
Yes, if you plan to only use the Quest 2 connected to a PC then the 256GB version might be too much. But, when you get the Quest 2 I think you will find that ability to play in other places too good to pass up. Playing games like Beat Saber, Pistol Whip, Thrill of Fight etc. without the need of a computer at all is brilliant. Then there are some exclusive games like The Climb 2 and Resident Evil that you can only play on the Quest 2.
The Elite Headstrap is fine. But, there are better options.
Things that you should consider buying (depending on budget.)
A router/access point dedicated for the Quest 2. (you home router might be good enough, but, in most cases the dedicated router is a much better option for wireless PCVR gaming)
A USB 3.0 cable recommended for use with the Quest 2. (Playing with a cable is a drag, literally, but, it's great to have one when you are playing sit down games or in emergencies, Something from Anker or Kiwi)
A different facepad. ( I would class this as a must buy, check out the VRcover site. They really improve the comfort and usability of your Quest 2)
IF you wear glasses a prescription lens insert is advisable.
OK, the only other thing is your PC. Is it up to the task? What GPU do you have?
If you are thinking you'll end up using it standalone as well as on pc it might be worth going 256gb, it also does allow you to pretty much not have to worry about storage. Some more AAA games will probably start requiring bigger space as wellThanks for the reply.
I was kinda edging to the 256GB with some little understanding but still thinking of perhaps liking the standalone experience.
In our house we have a RT AX88U main router and then a RT AX58U as a mesh device. It offers Wi-Fi 6, if that is needed.
So router wide we should be OK.
Any advice on the preferred head strap.?
The PC has a 5Ghz overclocked 9900k and a 3070 GPU, perhaps also OK for reasonable gaming experience.?
Ill take a look at the mentioned facepad, thanks. Also the cable.
Guessing that Virtual Desktop is the way to go.
Not too bothered about budget, well meaning that the cost of the Quest 2 is ok so the peripherals etc would be in line with that cost.
Thanks again
@Unseul
@KeanuIsLife
Just two of us for now as users but grandchildren will add to that.!
Thanks for your replies, send like the 256GB will the one of choice.
Perhaps the wired option might not be needed for us.
Need to look for head pads....
I just went with quality for oculus software and adjust everything else in game. You can also choose your resolution in oculus software as well in the devices section if you have extra performance.
What gpu you using?
Thanks
@Unseul Thanks, I have asked if JL will price match, they offer their typical 2 yrs warranty. Doubtful as they do not sell the bundle that Currys do.
will check out that strap pad, might be an option if I get the bare 256GB Quest 2 and go for the warranty over the bundle. Thanks again. At least I know that spending around £45 or so, standalone price, on the Elite headstrap isn't the only option - even with the thoughts of making one....!
Point taken about the powerbank, interesting thoughts about the balance of the unit.
