That was my old setup. Switched to the setup in my sig now. Board I had back then was a msi b450 of some form, can't recall the exact model.What motherboard are you using? And are those dimensions Height X Width or Width X Height?
What are the negatives of the vertical GPU? Can only fit dual slot GPU?
Cards over a certain size will have little breathing room against the glass. Looks like <3 slots will be fine.
hello guys I have decided to buy this case for my new build totally forgot about this case What aio do you suggest for cooling my 5800x I will be using a gigabyte 3080ti gaming oc as gpu and from your expereince guys how are temps when gaming are they good compared to a atx case ? this will be for work and gaming I like the idea of a small case for my small desk and advice would be appreciated thank you.
P.S im getting the nr200 without the glass cover
Assuming you are going to side mount the radiator, and are not worried about flashing lights / RGB, then you can't go wrong with the Arctic Freezer 2. The 280mm version just about fits. It's tight, but doable. Alternatively the 240mm will probably be sufficient, though maybe a tad louder than the 280mm.
The air for the AIO will be getting pulled from outside the case through a well ventilated panel, so thermals will be just as good if not better than many Mid-towers.
Slap a couple of slim fans on the bottom (or 25mm fans if they will fit with your card) and two fans at the top for exhaust, and you will have a very well ventilated system.
No worries I have decided on the gigabyte b550 auros ax for the Mobo, is this a good psu the cooler master v850? I know I need 850 for the 3080ti. And for those small fans what would you suggest here are the cards measurements L=320 W=129 H=55 mm (2.7 slot).
