Images of items I have purchased (except trainers [no feet pics]) - Do NOT use imgur, postimage or imgbb!
Because this is proper bespoke fitted?
Not, "kitchen units in the lounge"
Handmade and a cracking job by the looks of the pics :) good effort man :D
I mean they are exactly kitchen units in the lounge but the key thing is, they don't look like kitchen units in the lounge :p:)
Some connectors and a new hose gun to replace the leaky ones I currently have
Some additional weights
And a slight upgrade over my Nespresso pod machine
^^ great machine. You'll need this video bookmarked :p
It is the only one I've found where a human being does it.
A Weber BBQ, need to do some research as it's my first decent coal one.
And some more shelving for the garage, almost ready for the Civic no
Great shout. Well done for not cheaping out - the Master Touch, even if just for the ash catcher at the bottom, is the one to go for. Mine is.... 3 years old and still looks literally brand new. As I said to someone else in here, don't waste your cash on the Weber cover - it sucks. There are decent Amazon 57cm covers available.
And get yourself a chimney 111110000%.
Which one would you recommend? I've just been trying to find your post in here as I'm sure you linked one.
My loft hatch is tiny! I also use the box for the drivers door.
Garage loft lol. On the rafters. But I guess it makes a good door guard.
Ah, I did half think that. There's loads up there as it is and it's a great door stop without having to worry about carpet or something else on the wall.
Although now I've fitted shelving I'm wondering if I should have got some flooring beforehand.
Cheers, and which cover? There's loads of 57cm covers on Amazon. :D
I'm afraid I'm a double let down here. I bought this one:
https://smile.amazon.co.uk/gp/product/B000JUHJLY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
(and as you can see from the comments it was well regarded for the 57cm Weber) - but the image is distinctly nothing like the one that is cached in my order profile (August 2017 as it happens so my Weber is 4 years old and looking brand new) so I can't vouch for it - unless the picture is just different.
It looked similar to this one though...
https://smile.amazon.co.uk/JIESUO-G...eywords=57cm+bbq+cover&qid=1626815475&sr=8-10
