Caporegime
- 11 Mar 2005
- Leafy Cheshire
Yes it’s on the opposite side of the house that’s the issue and reading about it it would require a lot of work with pipes being routed through the loft etc
I get on well with the neighbours to be fair I wasn’t aware of any planning issues related to air con units attached to your own wall of your house?
Why is planning required?
Not too complex to route stuff through the loft and the pipework and electrics are minimal, it also means you have one cohesive system rather than the potential of two fighting against each other or at best two different control systems.
When I expand my system past the current units, the outdoor unit will be changed, some indoor units will be over the other side of the house and on other floors, it really isn't an issue unless your loft is inaccessible.
