The minimum PSU requirement for the 6900 XT is a 850W unit, so I would look here to start with.
etting the power limit in Radeon Software to -15% and click Apply, located in the upper right hand corner of Radeon Software > Tuning.
Try setting the power limit in Radeon Software to -15% and click Apply, located in the upper right hand corner of Radeon Software > Tuning.
Bit of a clean-up since the other post of my case.
And the cables need to be cleaned up. Or replaced with coloured cables.
But here is my 6900 XT's new home.
For the roll of honour please @Kaapstad.
My impressions:
Decided to move on my 6700 XT and 6900 XT Merc golden samples and switch to a Sapphire Toxic Extreme XTXH 6900 XT. Cheers @Gibbo and OcuK. First graphics card purchased from here for a while.
This card is really nicely built and looks fantastic with all the RGBs going. AIO pipes ruin the look a bit, but other than that looks wise it is lovely.
The actual graphics card is smaller than i was expecting and it looks tiny compared to the Merc 6900 XT it replaced.
In terms of noise and temperatures it delivers excellent temperatures up there with true water cooling and it is quiet. Silent on the power saving BIOS and quiet on the performance BIOS at 38% fan speed.
It is loud above 40% fan speed so I can see why some other users on other forums replaced the fans. I like the RGB look of the fans so I will keep them, however I like quiet in my man cave so I will run it at a max of 38% fan speed as even going balls to the wall it can keep the hotspot temp around 80c average and peaking at 85c.
38% fan speed is enough to play games at a locked core clock speed of 2750Mhz+ (500Mhz over MBA 6900 XT on the core clock) with the memory running at 2162Mhz.
Settings
It is disgustingly fast at these clock speeds and something air cooled cards just cannot do. When i say fast, it is now beating out LN2 and Chiller/water cooled 3090's on Timespy, Firestrike Extreme and Ultra in graphics score on 3DMark. @Besty
AMD Radeon RX 6900 XT video card benchmark result - AMD Ryzen 9 5950X,ASUSTeK COMPUTER INC. ROG CROSSHAIR VIII HERO (3dmark.com)
Power usage (PPT metric in HWINFO64) is anywhere from 350-400W in games at these clocks and it doesn't even have to work hard to achieve these speeds and keep low temps.
Would I recommend it? For the regular gamer no, It's just too expensive.
However, if you want the best (and it is the best I've used a lot of 6900 XTs) and you like to benchmark and/or you want to run games at the highest possible resolutions, clock speeds with no compromises (in terms of noise, temperatures or performance/FPS ) then I would recommend it.
Now I need to find a new home for the fastest golden sample XFX Merc 6900 XT round these parts.@djay It served me well.
@LtMatt Wow, this has certainly peaked my interest once more. My 3090FE seems very bland compared to this little beauty........................ Where's my wallet!
Morning, been reading over the headache you've had with MPT. I think as you mentioned you've changed hardware many time. What has happened is in the windows registry that MPT ultimately makes changes to, having used loads of different hardware. What has happened is it now will contain more than one device ID for the gpu so a fresh install of Windows might be the magic fix.
What you could do to not mess up your current drive is remove it a pick up a say 240gb sata ssd and install onto that, unless you have a spare in the house.
Just do a basic install of windows, chipset and GPU drivers. Then try MPT like that, you'll have a nice clean system too so might help squeeze out a few more points in 3DMark too.
Dont quite understand what the problem is with his Windows activation. If its a legit key even when you change hardware you can just do the six digit code dance on the automated line and get it activated again. Since I had Windows 10 I've changed my setup about 4 times and had no issues activating the key again.
Ye, its tied to the board or can be tied to the MS account too if required. Not a big issue when retail keys are under £3 anyway. And not that you even have to have windows activated anyway lol.
I think DocJekl issue will be down to having multiple GPU ID's in this windows registry. Easy fix really.
Many of the bigger YouTube channels have sponsors with key sites, allkeyshop lists many sellers. Just make sure to get a retail license to avoid dodgy oem keys been sold as volume or MAC.I've never seen cheap activation keys like you mentioned (in the USA) and I bought Win 10 Pro license for $129 on sale (the price of Win 10 Home) at an authorized vendor. I may need to find a cheap code for my second machine though.
I'll also need to find an app or windows tutorial to edit the registry to remove the other GPU ID's from the registry. Again, back in the old days, you could buy a registry cleaner app but just as often as not they would screw with the registry even more and require a clean install to be stable. Any suggestions for the easy fix, like the name of an editing/cleaning app? Thanks!
It's good to know they've made it easier with an automated line.
I was basically asking whether my being activated or not could prevent writing the SPPT change to the registry, since we can't customize windows when not activated and maybe there were other obstacles deeper down from not being activated?
Websites are international you know. There are tons selling cheap keys if you look.
When it comes to your current windows its 10 mins to do a fresh install to end your headache. It will give you a fresh registry, with over 20 years of PC experience I wouldn't do it any other way.
The automated line has been around since Windows XP.
Not activating Windows affects Windows settings not third party programs and the registry.
Only someone from the US could say that.Websites are international you know. There are tons selling cheap keys if you look.
Thanks! How do I make a clean install a 10 minute process?
That's a great price tbf on quality 1000W unit.Thank you to @LtMatt , just ordered a Seasonic Focus GX-1000, after shopping around found one for under £150 delivered. Should solve a few issues related to my 12 year old Hiper Type R2 770w..... kinda forgot how old it is and how not so great they were back in the day. My pc was tripping out under heavy load![]()
