Forum weirdness
What's really odd now is that I seem to be the only one who has access to post in the crypto forum :D
My test account does as well.
We know what’s causing it, we’re working on finding out why that’s causing it.
Can't see the Crypto forum here.
when I reopened a tab from last night the forum wouldn't load...the address had changed to something like
Code:
https://forums.overclockers.co.uk/community/general-discussion.12/install/install/install/install
etc etc
whatever the reason for that would be!
same problem here link is a bit long :D
www.overclockers.co.uk
Code:
https://forums.overclockers.co.uk/forums/cpus.89/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/install/index.php
yeah having to 'access the forum through the shop website link' too now, or it just adds the install/install at the end like above if using a bookmark
prob due to not understanding exactly how these links work but no idea what's happening now :p
with the crypto forum the only one thats having problems well the only one i've noticed i doubt this will be high on the list of priorities so buckle in it could be a long ride
Can you post the exact bookmark you're using please?
Or anyone really, can we see the links you're using that give the redirect error please.
