About 3.5mm, they are 30 months old now I think.How much tread do you have left/how old are they?
I ran the PS4S on my M3 for around 35k miles on the back, down to 2.2mm when I changed them, and honestly I couldn't tell the difference between brand new and nearly completely worn out! Really incredible tyres.
I had Goodyear Vectors (1st Gen) on my 1.4 Golf VII and they spun up and squealed quite a lot in this weather. But they also spun up a lot in the wet. Wasn't impressed at all.Anyone with all seasons, how are the tyres faring in this weather?
Just got an email from my local tyre guy telling me my new Cup 2's will arrive Monday. Timing seems good too as I got a low pressure warning yesterday afternoon and lots of wheel spin with traction sensors going mad, all very odd as after I put some air in the offending tyre it hasn't moved and seems fine again.
Thoughts on how is could lose pressure and then seem fine again once pumped up. No obvious nail in it?
It was a moment in time. I check them each time I go out, I tend to sit with the tyre pressures in the middle display when I drive. I think it is a sensor issue, hence the traction control going a bit daft as I have just popped out in the car and all 4 tyres are stable and the one I added air to is sitting a touch higher. This car has some very temperamental sensors. New tyres will go on after Silverstone on the 9th, subject to a check prior to the event to see if they are still all good.Maybe just the fact the temps are a lot cooler nowadays? Did you check the other tyre pressures?
I’ve got to get some new tyres for my Fiesta all round, and while I’ve been impressed handling wise by the falkens, a decent MOT highlighted they’re low on tread after 16k miles and also cracked. Most of my journeys are long distance on A/motorway - seems a little soon?
Anyhow, which tyres do you think I should go for?
I think the top rated are the Eagle F1 Asymetric, but they’re quite pricey per corner
I’ve otherwise been impressed by the Falkens, with excellent grip in the dry and wet compared to previous £30 tyres from when I got the car.
They’re also great with standing water
Extra info: due to sell the car in the new year.
205/40/R17
