Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
@Rainmaker Thats much better. Many thanks for the headsup and @Orcvader for posting the link.
this new layout is a complete mess as I still use Windows 7
I keep getting drawn back to firefox (even with the dislike for proton) because it just has a better 'feel' to it but luckily it seems to have a ****** annoying bug where for some reason it just won't scroll a page until I click on it which keeps making me look at others (same bug seems to be in librewolf too).
I've tried waterfox but while it currently looks and feels good, it has some annoying bugs on webpages, especially if they use google recaptcha where it just won't register my results until I've done 5-10 attempts, all of which are right. I've treid palemoon in the past and that had issues on sites not supporting it so I went off on the hunt for another option.
So I went and checked out the obvious alternatives of vivaldi and brave which both have pro's and cons, I prefer the overall feel of vivaldi but prefer the security of brave, brave has one HUGE annoyance (can't find a setting anywhere) in that it doesn't warn before closing the browser even if I have 20+ tabs open (their solution, reload tabs at startup...um no).
Going to give opera a try because it 'might' fix the lack of new tab tools (it's a speed dial) which I like on firefox but doesn't work correctly on chrome (thumbnails are broken) but in the mean time does anyone have any suggestions for an alternative speed dial that is clean and simple?.
Yeah... annoyingly after 19 years Mozilla started screwing up all the hard work we'd done making firefox feel like that comfy pair of jeans and keep trying to make it feel like we're wearing a pair of soft trousers lolAfter using Firefox for 20 years, trying to get away from it feels like trying to wear loose soft trousers versus jeans. Making you feel insecure.![]()
v92 installed and already "Firefox Suggest" is bugging me when I type an address in. Anyway to disable this?
That doesn't stop "Firefox Suggest" showing in the drop down list for me.In Settings --> Search, click on "Change settings for other address bar suggestions". Under Address Bar, untick all the boxes, or just the ones that you don't want.
I want to see the suggested URLs, but not the heading "Firefox Suggest" that's just appeared in v92.Strange, it's done the job for me.
/* Remove padding in bookmarks drop-down menu */
menupopup > menuitem, menupopup > menu {
padding-block: 4px !important;
The weird thing is, I have studies disabled, so I shouldn't even have the feature at all. I can't see it in the 92 release notes so no idea why it's enabled for me.I guess this might be the reason - "If you see "Firefox Suggest" entries in address bar suggestions but you do not see the above setting to show Firefox Suggest in the address bar, you may be part of an active study for improving the Firefox Suggest feature. See About Studies for more information."
So, we are all unwitting guinea-pigs.
Thanks for this, worked first time!Someone tagged me on the Reddit thread with a fix for the Firefox Suggest, go to about:config and set browser.urlbar.groupLabels.enabled to false.
