Pillock on Phone - Light Scrape
The problem is which I never knew before is that the Tesla stores all video files in smaller video clips and there was a small gap in the saved record. This one is the clip immediately before the front facing captures in the orignal clips.
yes it's a bit meh that the earlier shot that would indicate whether his behavour before, required more caution steering/braking wasn't recorded; (...Elon )
the steering input was just your car auto-steering too
That’s very impressive dashcam footage. I’d report it to the police via their website for a failure to stop rtc and then contact the company see if they’ll make it right.
Impressive footage that didn't catch anything, right
2nd cam down, right at the start.
Are you confusing seeing some contact with not seeing some contact? :p
As I said previously, it doesn't show the contact or accident directly but does show him crossing into the outside lane in a dangerous manner and evasive action.
Agreed, guy is a pillock. It is just a shame with 4 dash cams you didn't catch the contact.
We shall see if he admits it tomorrow :)
Also going to raise a complaint to Tesla as the gap in the recordings could have been vital to an investigation..
As apposed to single forward facing dash cams that would have been amazing at capturing everything?
took that as an ironic comment - indeed a std dashcanm would have been better.
I don't see why op didn't brake immediately .. the guy could have been having a blow-out say.
Didn't really think in the moment, the autopilot kicked in straight away to avoid and I immediately corrected and then he had gone out of the lane by then.
As apposed to single forward facing dash cams that would have been amazing at capturing everything? Or do you have a drone above your car at all times filming?
Having an additional front + rear setup would have at least caught the entire footage without missing 5-10 seconds prior to the event including it swerving around before hand, how close they were when the impact happened and it would have also caught the noise of the impact.
To be honest, it still looks like the third party were already across in the lane before they began passing them. I'm glad they seem to have taken this on and are investigating but some defensive driving would have probably saved them from having to deal with the incident. They should have really noticed them drifting way before the front of your car was near them and could have backed off until it was safe to pass/they were back in their lane. I'm sure we've all been in situations that we can learn from and it's easy to judge when it isn't you/you have time to think about things, hopefully this gets sorted out with little fuss :)
Was the car already on AP at the time? Curious to know whether Tesla AP will react and attempt to steer out the way if it notices something like this without it being active at the time.
To be honest, it still looks like the third party were already across in the lane before they began passing them. I'm glad they seem to have taken this on and are investigating but some defensive driving would have probably saved them from having to deal with the incident. They should have really noticed them drifting way before the front of your car was near them and you could have backed off until it was safe to pass/they were back in their lane. I'm sure we've all been in situations that we can learn from and it's easy to judge when it isn't you/you have time to think about things, hopefully this gets sorted out with little fuss :)
The car was on AP with myself with myself holding it as well. We didn't really notice the behaviour till this incident and then after as well.
Slightly OT but have you had any examples where AP has attempted to move you out the way of an incident without it being on prior to it sensing it? Really curious as to when the tech might take over/when it won't.
Not for steering that I've noticed. But It has definitely put the breaks on or put more force on them a few times over the last 4 years that I've had Tesla's.
Mobile repairers usually charge £150-200-350-400 per panel (depends on panel size, paint finish & how time consuming to match) not sure you would get it repaired for £50!
