Where are the DDC's
13 Sep 2012
Have I missed something? Can't seem to find any DDC pumps anywhere in stock
Would have been happy with used but can't find anything
Needed at least a DDC 3.2, overclockers are you getting anything in stock anytime soon like the new 4.2?
21 Dec 2019
Planet Thanet
You asked in the wanted section?
Someone is bound to have a used ddc laying around
And there's a forum section you can directly ask ocuk
About upcoming products too
Edit
Not sure if you are eligible for MM wanted section
If not then ignore that part
5 Mar 2017
Cambridge
There's a B-Grade 3.2DDC + Top and Heatisink for 70ish. Not too bad, considering if you use the pump and the heatsink, it's not too bad, plus you can sell the top or save to sell with the pump later, if ever needed.
Good thing about those is that the screw used as mounting would allow a small fan to be installed right behind the heatsink if the pump will be used on a distro.
OP
13 Sep 2012
Edit
Not eligle for wanted section unfortunately but thanks
This was a good shout, I never even thought about the clearance section for some reason even though my distro and blocks came from it!! Doh!
Got in contact with Rob Gould and now have one on the way
Thank you
21 Dec 2019
Planet Thanet
Yeah I wasn't sure if you're eligible
Kind of think there's different criteria for
Long term members when it comes to members market
Have definitely seen people in there with
A way lower post count than I needed to Access MM
but they have been members way longer
Silly question perhaps
But have you actually looked to see if you have MM available?
21 Dec 2019
Planet Thanet
And 1k posts may sound a lot
But you can actually do it relatively quickly
There's a ton of forum sections to post on
Plenty aren't PC related
Just to show how useful it can be
There's a DDC 3.1 and a DDC 3.2 on about the 3rd post
From the top On MM :)
18 Oct 2002
Scun'orp
Yeah, I had a 18W DDC burn out on me a few days ago and replacements are very hard to find. I had to replace it and its reservoir with an old D5 unit.
Out of interest how old was yours when it died? I've been water cooling since 2009 with the same 18W DDC, running at least 8 hours every day, so that's like 12 years of constant use. Any tell-tale signs it was on its way out you could maybe have detected or anything like that? Might be useful for anyone else with a DDC reading this thread to chip in and report how old theirs is, or how long it lasted if one has died.
