Out of interest what ratio do you guys use your BHAF at?
I do 2% for maintenance washing, via a pump sprayer. Saves the faff of setting the snowfoam up and swapping lances.
Polar Blast here too. I don't calculate anything, that's just additional faff. I smash stuff in and if it works I stick with that method.
What lance? The lance makes a huge difference. I'd never be able to get that thick a foam on the Autobrite!
Interesting, I have a cheaper 'copy' (Pro Kleen) and that would get Polar Blast so thick you'd start to worry if it'd still be sat on the ground by the next weekendWhat lance? The lance makes a huge difference. I'd never be able to get that thick a foam on the Autobrite!
The attachment it comes with is likely a detergent dispenser, not a foam lance.It’s a Worx Hydroshot which is a portable pressure washer which can take its water supply from a bucket. There’s an attachment you can fit on the end with a soap bottle. I don’t have access to water so this is a god send.
Still without all that foam it did a good job.
The jet wash might be fine but you'll never get foam out of the detergent dispenser. Get yourself a proper lance if it fits your Worx.Yeah I fill the detergent dispenser with 60ml of Polar Blast and 300ml of water, then fire it out of cannon that the dispenser bottle is fixed to which sprays the car with the formulation.
I guess this isn’t as powerful as a proper foam lance but it’s better than nothing as I have to park in an underground car park with no power or water.
