Need help saving data from an NVMe SSD
smr
smr
6 Mar 2008
Leicestershire
I've got a laptop which is dead, faulty mobo probably.
Taken the SSD is out which is one of these NVMe ones. It's a Toshiba, model number kbg30zmv256g
I've bought two SSD enclosures now and neither work, could anyone suggest one that will work?
25 Feb 2003
Deep dark hole
Try a search for one of these:
FIDECO M.2 NVME External SSD Enclosure, PCIe USB 3.1, Gen 2 Adapter with 10Gbps Transfer Rate, USB C Hard Drive Caddy/Case for M-Key & M+B Key NVME SSD 2230/2242 / 2260/2280, Support UASP
I can't see in the specs whether it is an M-key or M+B Key drive, but I have a
WD Blue SN550 1TB High-Performance M.2 PCIe NVME SSD
in mine, so compare them spec-wise and see?
smr
smr
OP
6 Mar 2008
Leicestershire
Thanks for the reply. I'm not sure what I'm supposed to be looking at now as I've bought two SSD enclosures for it but neither work.
This is the drive...
smr
smr
OP
6 Mar 2008
Leicestershire
The second one I bought is this one... which sounds the same as the Fideco one?
LEMORELE M.2 NVMe SSD Enclosure USB C External PCIe B+M/M-Key SSD Caddy 10Gbp UASP USB 3.1 Gen 2 M2 Reader Aluminum Thunderbolt 3 Case Compatible with Intel 760P, Kingston A1000 Tool-Free
25 Feb 2003
Deep dark hole
It looks like it is a B+M drive (a cut out at both sides), which it does accept
Where I got it from have a good returns policy, and with it being less than £20, worth a punt?
smr
smr
OP
6 Mar 2008
Leicestershire
Yeah I suppose, it's just that the Lemorele is the same thing and that doesn't work? Or is this one different?
Unfortunately I don't have a computer with an M2 slot - my motherboard is very old!
smr
smr
OP
6 Mar 2008
Leicestershire
Just to double check as well that my Motherboard would support it... the tech specs for the PCIE slots..
  1. 2 x PCI Express x16 slots, running at x16 (PCIEX16_1/PCIEX16_2) (Note 2)
  2. 2 x PCI Express x16 slot, running at x8 (PCIEX8_1/PCIEX8_2) (Note 3) (The PCIEX16_1, PCIEX16_2, PCIEX8_1 and PCIEX8_2 slots conform to PCI Express 2.0 standard.)
  3. 2 x PCI Express x1 slots
  4. 1 x PCI slot
Don
19 May 2012
Spalding, Lincolnshire
Should be fine in one of the PCIe x16 slots.
Depending on how old the motherboard is*, it may try to boot from the NVME (in which case you would need to use the boot menu or bios to select your normal boot device)
* bootable NVME was socket 1150 onwards (4xxx intel cpus) I think
