Caporegime
- 7 Apr 2008
- Lorville - Hurston
i actually did descale the machine about a month agoFor me pf has blown out for 2 reasons
mostly worn/non-pliable gasket that cause the pf not too lock as tightly, although handle is in same place (I had problems buying correct size conical gasket to replace it )
secondly (rarely) problems with the over pressure valve causing too much pressure and blowing off the pf (machine neededa good descale)
