Deleted member 651465
D
See above... I didn't go for the grant, so may be cheaper if you factor that in.all seem to be similar price, with the grant for the zappi it was £860 i think including install
I was considering the Zappi but after I saw how small the Easee was, the fact it can be untethered and how they daisy chain together, I changed my mind.yes i actually saw your comment a while back. Was gonna go for tesla charger, but that is excluded from grant as it's not 'smart' but it's cheap enough, but you need to put the extra device in the consumer box (a la lightning rod) but then I looked in to it and it seemed consensus was that is actually a little bit dodgy theoretically, so zappi solve 'it' a different way that seemed to reassure me so i just went with zappi the install said he's put a bunch in so just went ok then
turned it down for the same reasons you did
Sorry, I was referring to the fact that it was not "smart". I would like to be able to schedule charging and see how much it's costing etc.Are you talking about the new version 2 Tesla charger, as I thought that fixed the issue surrounding the first ones failures?
Also, if I put 2x Tesla chargers on the drive I know I will have to explain to my wife that she can use it with her Audi as undoubtably she will assume they're only for Teslas
Supercharger = the freestanding chargers you see at motorway service stations. Latest gen 3 can charge at 250kWi've seen this phrase 'tesla destination charger' used a bit. And been looking at apps like zap app and stuff. What is 'destination charger'
Why bother? Does it reduce the tar that gets flung up?Has any one fitted mud flaps to their model 3. Looks like you have 3 options tesla oem, amazon specials, or rally armor does anyone have any pics to share and experience?
Sorry I didn't mean to sound daft, but there's not normally that much mud on the roads so I find it funny they get called mud flaps (guess from rallying). I've never fitted any before so wasn't sure if there was a need or not.yes and grit and stones and mud etc
These are highly recommended on some other forums. Clip on, no drilling and they're a decent fitHas any one fitted mud flaps to their model 3. Looks like you have 3 options tesla oem, amazon specials, or rally armor does anyone have any pics to share and experience?
Does Tesla supply/fit the PPF for the rear arches and mud flaps in the UK? I've seen it mentioned that they do in some countries.
