Get out. lol.Bucket wash with fairy liquid
Get out. lol.
Pretty sure it's got all sorts of abrasive type stuff and salty juice in there though so not quite sure why it's being used in 2021!
Get out. lol.
Does anyone watch the detail geek on YouTube? He has his own stuff too.
You don't wax a car that isn't clean nor do you wash straight after waxing. This is why you also own a traditional microfibre drying towel. Dry it with the towel than carry on as normal. Once the car is waxed, you can use the blower to dry instead of the towel or as a combo. Once the water beading starts to wain, you re-wax it or you use a top up product before the beading goes completely.To stand any chance of removing water from a car with a leaf blower you have to wax it first, which I get. However prior to waxing you’d have to pre wash it, rinse it and then wash it with a microfibre mitt and shampoo after which you’d need to dry it and the leaf blower won’t help you.
So how often do you wax a car without pre washing it first? Otherwise I don’t see the point in drying it with a leaf blower if you have to dry the car anyway after a wash.
Also what’s the point of rinsing a freshly waxed and buffed car with water. It only makes sense if you were to apply a layer of wax then a couple of weeks later just wash the car so the wax coating beads the water which allows it to be blown off by the leaf blower.
He seems to have a good rep online unless anybody here knows differentId struggle to trust anyone who also sells their own branded cleaning products to provide an unbiased review.
It’s going to be difficult to tell whether a product is any good through a YouTube video, so you have to rely on their testing and own advice.
Hence why I usually go to the Forensic Detailing channel for any advice on cleaning products
That is pretty impressive! I may well give Snow Foam another shot with one of those. I had the generic 'sold as many brands' lance for my Nilfisk and it just seemed to spit out soapy water without really going thick.I changed to the Nilfisk snow foam lance and got to use it today,. Very impressed for the price. Better performance than the Autobrite metal pro ones that are often rebranded by others too and cheaper/smaller.
This is NOT the same one you get with Nilfisk washers. Those bundled ones are toilet.
Polar Blast here too. I don't calculate anything, that's just additional faff. I smash stuff in and if it works I stick with that method.
Its quite noisy, there's two speeds one is noisier than the other...
I thought it was quite noisy didn't realise its 89 decibels! Going to have to wear some ear plugs when I use it.
