@LtMatt Well, I tried the above and no luck, still low FPS at a reload.. BUT.. I installed Steam and the game on my second PC which has a 1080Ti and there it was no problems. It dipped a bit during the reload but once it loaded back in game the FPS was at 60. So might be that the game is not optimized for AMD drivers or just me that having a really bad luck with the game !
To bad you not familiar with the game but wouldn't expect you to be that for all the games out there ! Although if you can inquire with your colleagues maybe one of them are ?
@AMD_Vik Pinging you as well incase you might have more information ?
Edit: Well just found this over at steam discussions for the Encased game and it's more or less what I been experience:
Hmmm I actually think it runs on Unity.
Less likely unreal engine but looks like unity to me.
If you are an AMD GPU user then there are often issues with Unity.
In general unity often toast the GPU lacks frame limiters.... On AMD as a cherry on top it often crashes display drivers and other fun strange things. This game is no exception. It all started with the new Mechcommander game for me.
Then again Wasteland 3 runs fine and it is also unity. There are games that work as intended.
Source:
Link to steam Scroll down to reply 7 and then a bit further down on reply 10 a user says this:
Looking at the install folder, it is most definitely using Unity.
UnityCrashHandler64.exe
UnityPlayer.dll
Right there in the root.
So, it might not be a driver issue after all but a game platform issue ? If that's the case I guess I have to keep playing the game on my secondary PC.
