Pads your using are way to thick , you need 1.5mm Gelid Ultimate on the front ( die side ) and 2,0mm Gelid ultimate on the back . i tried 2.0mm front but core wasn't making good contact . with 1.5mm core is now perfect and memory sits at 74 to 82 depending on fan speed![]()
A lot of the guides out there and YouTube videos are stating 2mm on the die and 3mm on the back.
I agree with you though, I do believe now they need to be thinner.
) i decided to give the pads i had a go ... i tried the 2.0mm first as the guides suggested and while the memory was very cool ( 70deg ) the core was around 75 to 80 and upon disassembly i could see where the core wasn't making contact properly . redid the lot with 1.5mm and as above has been spot on now both memory and core. so if using Gelid Ultimate it is 1.5mm front and 2.0mm rear
