- 28 May 2020
Hi All
My current build uses a Cooler Master Masterbox TD500 Case which came with 3 RGB fans.
Two of the RGB's are not working so I was going to buy a 3 pack to replace the standard 120 RGB fans. I am looking at the SickleFlow or MasterFan they are a similar price but slightly different spec. I think the Masterfans are the most recent but I was wondering if you guys could help or come up with another solution.
I am thinking of putting in a 240 or 360 AIO either on the front or top, then using the working fan on the back to exhaust then buy what ever I need fan wise to cover the front and/or top. PC spec below
• CoolerMaster MasterBox TD500 Mesh with 3 120 RGB fans installed Front
• be quiet! Pure Power 11 500W 80 Plus Gold Modular Power Supply
• Corsair Vengeance LPX Black 16GB (2x8GB) 3600 MHz AMD Ryzen Tuned DDR4 Memory Dual Kit
• AMD Ryzen 5 3600 with stock cooler
• MSI MPG B550 GAMING EDGE WIFI Motherboard
• MSI Radeon RX 5700 XT 8GB MECH OC Graphics
