i cant find the rift version, tried Steam, tried the Township Tale website, clicking on shop takes you to Oculus, not there either![]()
I've got Virtual desktop working with it, airlink looked very smeary. Takes a couple of goes to get the order as it wishes though.
Did some rock cutting to start on the way across to the carpentry. Did a bit of a chest run too, looking for tnt to open up the dust bowl.
will get done as soon as home......tryin to stay in work till at least 1800.....
but september weekend so buses are crap.....thats a valid excuse....
G
Also, I tried using Virtual Desktop and Air link. It was very awkward getting Virtual Desktop to work with the game. You have to launch Virtual desktop, then press the launch steam VR button and then play the game. Airlink was easier, connect to your PC and just start the game from the Alta Launcher on the desktop. My problem with Air Link was the sounds weren't playing.
there are 2 versions , 1 via Steam VR and the other via Oculus, try downloading the other one and give it another try
just accepted your invitation for server , thanks
I assume you have a private server ? think all need to chip , get 8 people, only £1 a month then![]()
Don't worry about it
There is only one version, that's the one you download from the TownshipTale VR. You can switch between using Steam VR and Oculus in the game's launcher. I got it working in both, I was just telling other people how to get it running in Virtual Desktop as it's easy to do with Airlink.
I will be leaving shortly and won't be back online until after 7:30pm, so no point rushing home!!
for gods sake man...stop removing my very valid excuses for leaving work early
with the pc version its free but to do the server you 'donate'...either a 1 off/yearly or monthly or quarterly?....
Looks a bit nicer. I like the fact stuff loads in from further most of all.
So far though, not much different but I'm sure that'll change.
Hoping to get tnt since woodis easier too get on the dust bowl area.
I try opening it in oculus but it still opens steam vr.
