- 30 Sep 2005
The issue is that despite individual headsets having good features there's no one headset that combines all into a good all-rounder.
The Quest 2 has bad FOV, bad default headstrap, no lossless PC connectivity and awful IPD adjust.
The Index is expensive, lower resolution than recent headsets requires base stations for tracking, and doesn't have wireless.
The G2 has awful controllers and bad controller tracking, and has had cable issues.
We need a headset that mixes all the good parts - relatively cheap, high resolution good FOV, decent IPD adjust, wireless capable, and comfortable out of the box.
You know, if they made a quest headset with even a little bit better FOV, and added a direct DP port it would be much better.
