- 6 Jan 2013
- Rollergirl
All of those are OK in my book. Those weren't what I was discussing.
Although I do think some of those should be controlled though.
Increasing property value increases for example have a massive negative effect on the ability of first time buyers to get into the market. It's why more are stuck renting now and house ownership amongst the younger generation is the lowest its ever been
The same with profit margins/markup should be limited too.
And as far as I know none of what you mentioned can be created by GPU's out of thin air from a PC in someone's bedroom.
You've chosen a thread about GPU mining to express your opinion, but clearly your disapproval isn't exclusively with GPU mining - it appears you have a problem with capitalism in general.
Your understanding of crypto is very limited; I hope you research your various other annoyances a bit better.
