Hello,
I am doing a refurb of my house and will be running new power and NW cables to the whole house. I am looking at either get Cat6a or Cat7(a), the cables will have few runs parallel and crossing electrical cables so I am thinking U/FTP or S/FTP, do this shielded one need to be grounded as well (oinly worked with shielded Cat5 before)? I dont mind spending bit extra for Cat7A if anyone can find a decent 500m Reel, or has any recommendation (once I have the floors up so it doesn't have to be changed for next 10 years
I have an Cat5a crimp tool but I think it will be crimped to patch panel on cabinet side and wall plugs on room side.
Also any good recommendation for double port (as low profile as possible so i dont have to dig the wall too deep
) wall sockets and patch panel would be most welcome.
The cables will also be used for CCTV as well but only going to outside plastic box so will not be exposed to elements. I am also going to run 4 cables (HA) to the shed in a plastic pipe in the ground / Likely next to armored power cables.
Thanks for any suggestions
