Too Many Linux Distributions?
20 Feb 2011
If I need a Linux install for anything then I download Mint. I suspect most folks will act similarly unless they’re have a specialist function in mind such as security pentesting or privacy. The many smaller distros are fun and often provide alternative GUIs or ways of working however no one is forcing anyone to download them! Someone moving from Windows to Linux will do a quick Google and end up on Mint or Ubuntu or perhaps PopOS, and that’s no bad thing.
OP
19 Oct 2002
The only bad thing about Mint is it is not rolling, no need for bleeding edge, but updates to the latest tested & bug free software wouldn't hurt.
13 Jun 2016
UK
I am afraid I disagree, to me that's like saying there's too much choice when buying a car. I like the choice, the freedom to have what I want and see which suits my needs etc best. Anyone coming from Windows, even just typing into Google, is likely to work out fairly quickly that they will be well served by Ubuntu, Pop OS or Linux Mint.
In the past I have used Ubuntu, SUSE Linux, Debian and Pop OS. Recently installed Arch on a spare machine to see what it was like, but ended up settling on Manjaro KDE, which I dual boot with Windows 10 for compatability. Quite liking Manjaro and definitely liking KDE over Gnome right now.
28 Jun 2013
I only look at the most popular ones, just because there are hundreds does not bother me. I thought that was the point
5 Mar 2010
You'll probably find 90-95% of users will use the top 5 distros, and then the rest will have tiny user bases.
All our Dev environments are either centos, rhel, Ubuntu, or fedora. no one bothers with anything else.
17 Aug 2009
Sure there might be 300+ but how many are quality and have good support and don't ask much of the users technical competence.
The ones which tick all those boxes deserve to be popular with the masses.
Man of Honour
13 Oct 2006
I pretty much stick to Debian and Ubuntu personally - a lot of these distros are like all these crypto alt coins - launched with a lot of fanfare and largely go nowhere.
3 Oct 2013
I am thinking of Manjaro, just the bleeding edge packages are a bit scary. Not wanting to get a buggy package..
Manjaro dont do bleeding edge, They are generally a little later than plain arch. Roughly a fortnight or so. If there is a problem with say plasma they skip it until the next revision/build.
OP
19 Oct 2002
Good, I am on Solus now & that was the thing I was worried about.
13 Jun 2016
UK
I've swapped to Manjaro after mainly being a Ubuntu and derivatives user; generally I'm finding it very, very stable. I guess you might be unlucky if you install loads of packages from the AUR, but I've yet to have anything buggy.
OP
19 Oct 2002
I plan to stay away from compile your self packages.
29 Jul 2003
My biggest grip with Linux. Most of them are buggy as hell and not user friendly.
They keep releasing new version to beat other distro without ironing out the bugs first.
