Don
- 20 Oct 2002
- Oxfordshire / Bucks
oh
good game, got loads of copper ore, and sandstone and rock
i can finally finish building the Well
which I'll do tomorrow
blew up the shortcut behinds the blacksmith
found an odd looking carpentry recipe
found more cauldrons and a few bits and bobs
I think it was your poor connection that was affecting your ability to hammer nails. It was really bad! Like when we would had you something, to us it would look like it fell on the floor, but then it would reappear in your hand. It was nothing to do with my amazing mentoring skills, I was patient, understanding and encouraging when you made mistakes
Anyway to improve your connection at all? It was so close to been playable. Were you using your Phone's 4G connection? Maybe check to see were there any other apps running that use internet and make sure no other device in your home is trying to use the connection at the same time as you are trying to play.
Hope you can get it good enough so you can come on another time or at least get in a few hours on your own.
Just had a thought
i think you need to be careful when picking a skill from one of the many shrines
i think once all your things are filled up on that part when you put your skills, you cant have any more
Not sure how many slots there are, possibly 8?
