- 11 Jan 2007
- *̡̡ı ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡
Confidence is low but I will give it a whirl. Are you doing it from within Windows or boot from USB?
)Downloaded the "final" ISO from the link above and installed on my ye olde Haswell. Still getting driver updates (even though it failed because my internet gimped out)
https://i.imgur.com/oY1XGfJ.png
Yeah, it is The processor isn't supported for this version of Windows.
Just installed the latest insider preview beta on a dell optiplex 330 with a xeon E5450 c2q.
Used the 11 iso files but swapped out the sources folder for a win 10 sources folder, but kept the win 11 'install.wim' file in it. No TPM or secure boot check issues.
I have a 4690K in one of my machines and I had to:How did you manage that? It’s telling me my 4790K is unsupported…
I’d like to give 11 a try, my 10 install seems to have gone a bit flakey, but I have no desire to upgrade my hardware yet as it’s still fine for my needs.
Great stuff, thank you.I have a 4690K in one of my machines and I had to:
- Enable Secure Boot in the BIOS, which also involved converting my drive from MBR to GPT (or it won't boot)
- Use the GitHub media creation tool to create a W11 ISO
- Do a fresh install (it wouldn't work from within Windows 10; kept saying hardware was unsupported)
The biggest benefit for me so far is for people with HTPCs / media stations in terms of HDMI handshakes and HDR.So what's the general opinion on windows 11? Wondering if it's worth upgrading day one, or waiting for it to mature a bit.
