The AMD Driver Thread
AMD Rep
Vendor Rep
2 Apr 2021
Kent, United Kingdom
@AMD_Vik One of the fixes says "Some users may experience high idle memory clock speed values when two or more monitors are connected to their system." however the moment I turn on my 2nd monitor, even if I turn down the hz to 60 from 144, my 6900XT memory idle speeds jump to max and stay there. If I go to display settings and change to Only Show Monitor 1, the memory goes right back down to your "normal" idle speeds.
Could be a maximum throughput or even a VBI thing at play here. Which display models do you have?
Have you tested any other refresh rates on your secondary display to see how they behave?
21 Jun 2018
Ashton
I have an MSI Optix MAG274QRF QD (165hz 1440p) and a LG 27GL83A (144hz 1440p), both connected through DP.
The MAG has options for 60/120/165, and the LG has 60/100/120/144.
After checking the only way that the memory will go on idle while having both ON is if they are both set to 60hz. The moment I try to increase either off to 100 in case of the LG monitor, or more, it gets stuck at max speed. When this happens consumption stays at around 35-43w according to Radeon Software.
AMD Rep
Vendor Rep
2 Apr 2021
If you have the time, could you tell me what your idle memory clock behaviour was like on 21.8.2?
21 Jun 2018
Ashton
Sorry I didnt have time yesterday.
I just installed 21.8.2, and it does the same thing. If they are both set to 60hz it goes on idle, anything but that causes the RAM to stay stuck on max.
AMD Rep
Vendor Rep
2 Apr 2021
Hey there,
If that the case, it's unlikely you would be affected by the idle memory clock fix that went into 21.10.1, as that went in to revert a change going into 21.9.X causing certain display configurations to idle at the maximum memory clock when they would otherwise be able to gear down.
21 Jun 2018
Ashton
Hey there,
That is fine, so is this still considered a bug or is it normal behaviour?
AMD Rep
Vendor Rep
2 Apr 2021
In this case, I'd say it's expected behaviour.
If this is caused by VBI then you might have some luck gearing down with the Custom Resolutions feature in Radeon Software or with CRU, though I'm not sure what can be done if it's due to display bandwith besides reducing the refresh rate (or resolution but I wouldn't expect anyone to do this) on one or both of your displays.
AMD Rep
Vendor Rep
2 Apr 2021
really wished amd would pull their finger out their ass and sort their drivers out sick of driver timeout errors
Hey there, could you tell us how long you've been experiencing driver timeouts with your 5600XT?
Could you pinpoint it to a specific driver version, for example?
Do they still occur for you at stock settings? (without the undervolt to 900mV)
2 Jan 2012
UK.
Hi, not sure if this is the right place for this question but here goes.
Any AMD guys I redeemed a copy of Far Cry 6 with product a while back and it says I've spent the credit. I've never been sent a code to redeem and the game has not appeared in Ubisoft connect, are there additional steps to redeem the game.
Thanks for any help :)
Caporegime
OP
12 Jul 2007
United Kingdom
Conact the Rewards support team for this type of inquiries.
Support - AMD Rewards
