*** Microsoft Windows 11 Thoughts & Discussion Thread ***
21 Oct 2002
West Sussex
Just done my laptop with online upgrade, took 1 hour and everything seems ok. Only thing i had to do was remove all shortcuts icons again, which was done via regedit entry
Processor Intel(R) Core(TM) i9-10885H CPU @ 2.40GHz
Installed RAM 32.0 GB (31.8 GB usable)
RTX2080S full version
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
Shortcuts icons? Not sure I follow.
I did notice the added bloat apps installed though like some games, WhatsApp was preinstalled among others. They are Windows Store apps though so easily uninstalled. I also tidied up the start menu all apps area as it became cluttered. I now have one big open list of apps I can scroll to find without trawling through folders etc.
For reference there are two locations start menu items are stored in Windows:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs
C:\Users\USERNAME\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
Depending on the type of install done for each app, the shortcut will reside in either of these places. I like to keep things organised hence why manually managing this sort of stuff is my preference.
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
Nope, if the media creation tool lets you install it after accepting the prompt, then can't see any issues resulting. A lot of people have already done it this way.
28 Mar 2006
PC meets everything with the exception of secure boot being switched on. Can't seem to enable it in the BIOS (follow the instructions in the manual/guides online but can't seem to get it into user mode). Quick google states that I have to change the format of my boot drive.
Might use this as an excuse to do a fresh install
Caporegime
17 Mar 2012
ARC-L1, Stanton System
What's so funny?
https://www.youtube.com/watch?v=go1Iffj3asM&t=2318s
https://hothardware.com/news/microsoft-windows-11-performance-preview
https://windowsreport.com/windows-11-benchmark-tests/
Microsoft has a history of new OS being worse than the one its replaced, they usually fix it 'eventually'
Those links might not be true or they could be early access teething issues and its all fine now, its why i'm asking, i have the option to update but i'm not going to do it if it turns my 5800X in to a 3800X.
If some one here with a Zen 3 CPU doesn't mind running a quick CPU-Z benchmark i would appreciate it, thanks. :)
https://www.cpuid.com/softwares/cpu-z.html
Permabanned
23 Apr 2014
Hertfordshire
What's so funny?
I can have a go but I only have a 3900X. Those links are quite old now.
Caporegime
13 Jan 2010
Llaneirwg
I think my desktop doesn't have secure boot/tpm?
I'm not actually sure.
I'm not fussed if I can't upgrade. Win 10 is fine.
But I won't be updating my surface book if I can't update my desktop
18 May 2010
London
So what's the catch regarding ftpm?
I do not have a TPM chip, but I can enable ftpm in the bios.
I don't use any encryption like bit locker etc, so I assume everytime I do a bios update no issues will occur assuming I enable ftpm again.
18 Oct 2002
Fife, Scotland
You can convert it with the tool already installed onto your Windows.
https://docs.microsoft.com/en-us/windows/deployment/mbr-to-gpt
Fairly straightforward, just watch the vid
