Do you get the options to get the quick launch section back and to remove the W11 version (icons in the middle)?
It's not, but you won't be missing anything out by installing it. Everything works. Just follow the earlier mentioned methods. I have the same CPU.Looks like my i7 -6700 cpu is not on the compatibility list.
You can restore quick launch yep via right clicking the taskbar > toolbars > links then copy pasting your shortcuts you want or dragging whatever to the links toolbar
As above though, you have various options to get how you like it.
Quick dirty gif I did to demonstrate:
It took ages, and a few UAC type prompts, downloading patches, re-entering my password etc. But yes, it loads. You just have to be really patient, don't just give up after 20s of it initialising etc, it took a while (maybe it has to build a cache or something I dunno).Can anyone get ubisoft connect to load?
Can you do one for how to always show all taskbar overflow icons?
Anyone from a dev/insider preview been able to install the official release, if so what's the best way?
I know my cpu. it's a 4700k!
Old! Gen 4!
