- 24 Mar 2018
- Brighton
If i upgrade windows10 pro it turns into windows11 home
0x800F0830-0x20003 The installation failed in the SAFE_OS phase with and error during INSTALL_UPDATES operation.
For those who have used the upgrade utility to update a W10 install to W11 (without doing a clean install): Have you noticed any files missing, software missing or settings being reset?
This is why I always disconnect drives on clean/upgrade installs. It's asking for trouble and mistakes can happen. After all, Microsoft has a track record of botching stuff.
Now I just keep getting this:
I did have secure boot enabled but have since disabled but still the problem happens. Ironically, it gets to 11% installed then rolls back with that error.
I don't want to do a clean install but I do have a spare SSD I could try.
That's what I did, after using Macrium reflect to take an image of W10 just in case.
I have a system tray of icons on each start up of W10 and a lot of software installed.
I was surprised, pleasantly, how quick and simple the change was to W11.
Nothing hasn't worked since and all my settings, files and network access, mapped drives etc are exactly the same.
Nothing reset.
It just worked well for me.
If i upgrade windows10 pro it turns into windows11 home![]()
how did you upgrade it ?Nope, i upgraded and im on win 11 pro
First issue I've found - If I use direct mode on my Creative AE 5 the volume slider in Windows or the Creative app does absolutely nothing. In app volume controls do seem to work though in things like Musicbee
All righty
List of features removed in Windows 11 - Wikipedia
Taskbar[edit]
The following taskbar features have been removed:
- Support for bringing an app into focus by dragging a file to its button[9]
- Support for moving the taskbar to the top, left, or right of the screen[9]
- The People button;[1] its
- The Peek button
- News and Interests has been succeeded by the "Widgets" panel.
- All context menu items, excluding a link to its Settings menu.[9]
- The Network flyout
- "Some icons in the System Tray," although Microsoft doesn't specify which[1]
- Support for third-party taskbar components (deskbands)[1]
- The option to hide or customize individual system tray's icons (Only third-party icons can be hidden or shown)
- Support for launching another instance of an app via Shift + left click
- The upward swipe gesture for jumplists
Start menu[edit]
- Support for showing each instance of an application as a separate button in the taskbar
Some functionality from the Start menu will be removed and replaced with other features.
Windows shell[edit]
- Folders and groups[1]
- Live tiles (the Widgets app provides portions of what the live tiles of Windows 10's bundled apps once provided)[1][8]
- Pinned apps and sites[1]
- Recent and pinned files on apps
The following parts of the Windows shell have been removed:
In addition:
- Quick Status
- Tablet mode[1][7]
- The Timeline feature in Task View[1]
- The Save Search option in File Explorer
Bundled apps[edit]
- The touch keyboard no longer docks in screens larger than 18 inches.[1]
- Windows no longer synchronizes desktop wallpapers across devices with a Microsoft account.[1]
- Folder previews for images or videos contained in that folder in thumbnail view/large/extra large icon views are removed. The generic folder icon is now shown for any folder containing images or videos.
The following apps are no longer bundled with Windows 11:
- 3D Viewer[1]
- Cortana[1][2][3]
- Internet Explorer[4][5]
- OneNote for Windows 10[1]
- Paint 3D[1]
- Skype[1][3][6]
- Wallet[1]
Quite a long list of things........
Pointless list is pointless.
