- 2 Jan 2012
- UK.
Conact the Rewards support team for this type of inquiries.
Support - AMD Rewards
No worries, a tab just appeared for me to link ubisoft connect and get the game. Thanks AMD !
Good to hear.No worries, a tab just appeared for me to link ubisoft connect and get the game. Thanks AMD !![]()
Just noticed that with clean install of windows 11 my vram clock on gpu is at max all the time sat on desktop, is this supposed to be fixed or do i need to read the past few pages for a fix.
No oc and no programs installed like afterburner etc, everything is at default settings.
its idle at 1988
driver - 21.10.1
Hey there, this can depend on your display setup:
Cheers!
- Was your GPU behaving the same in Windows 10 with 21.10.1?
- Can you verify that you're actually running 21.10.1 (Windows Update may have intervened in the background)
- Could you tell me what your display setup is? (model number, resolution, refresh rate)
What is 12 bpc?
As far as I know, 1.07 billion colours means 10-bit.
There are no monitors that can visualise more than 1.07 billion colours.
My philips TV supports 12bpc but my AV unit only supports 10bpc
It's not ok.
Most consumer grade displays (read desktop monitors and notebooks) are either 6-bit or in the best case native 8-bit.
I haven't heard anything about 12-bit. How many colours does it actually support?
What is 12 bpc?
Please let me know if anyone gets a black screen or your display loses signal when you enable 10 bit colour depth (Bpc in Radeon Software see attached image). If you get these symptoms in combination with HDR (either via Windows HDR option or in-game HDR option) in 21.9.1, 21.9.2, or 21.10.1 I'd like to know about it.
