New build - Next Steps?!?
OP
13 Sep 2009
Kent, UK
That’s a great list
crysis three I already have I’m keeping an eye on fps I’m not using a 4K display yet but that will come for now HD 1080p
so far crysis 3 hasn’t disappointed and neither has fc5 at max settings they both look and play amazingly - crysis 3 suggests it will need over 4gb of vram for the settings, not bad for a game released in 2013!
Witcher and Assassains creed peak my interest as do final fantasy and cyberpunk
metro might be one I look at but never got into it on console.
control might be one i consider depending on how the others go. I’m keen to see just what ray tracing is all about
currently sorting my Corsair rm850 PSU for payday trying to be sensible and not push my psu to hard - I don’t have doubts but why risk it especially now!
OP
13 Sep 2009
Kent, UK
Ok so bit the bullet today
I’ve ordered a Corsair rm1000x 2021 model psu £118 brand new so should help in terms of warranty and piece of mind - new rig has renewed my love of gaming so it’s gonna get some use and I am not paying for a toasted gpu!
OP
13 Sep 2009
Kent, UK
Looking good kp. Enjoy all the new games you can play at decent settings and fps with the new rig
thanks it’s been a while since I’ve built one and a while since I’ve been able to enjoy proper quality by comparison so loving it.
FC5 benchmarked at 60fps and min 59fps with everything turned right up so well happy. Will play it through again to enjoy the difference
working through crysis 3 currently - amazing how ahead of its time the graphics were
OP
13 Sep 2009
Kent, UK
Ok so I’ve conceded my budget rebuild has become anything but.
However I’m quite pleased and it’s been worth it!
now looking forward to the psu arriving as will make for a much tidier build and also has just enough connectors although interestingly doesn’t have the additional 4-pin atx I need to go alongside the 8 pin for the cpu. Although not strictly required would be nice to get it connected!
OP
13 Sep 2009
Kent, UK
You have to get rid of the Psu and replace it with a quality unit .
ok so I bought a rm1000x, unconvinced at first as per my reasoning in posts
however - fcuk me! This thing is a beast compared it makes my old one feel and look like a toy! Quality better by 1000x
and thus far no random crashes, it’s tidy, everything is plugged in no adapters or splitters and it’s quiet.
for what it cost the piece of mind is priceless! Never again will I cheap out on a psu!
Man of Honour
23 Mar 2011
West Side
Great news , enjoy.
OP
13 Sep 2009
Kent, UK
@mickyflinn cyberpunk isn’t bad - expected more from the graphics but that’s not to say they aren’t good. It’s quite a lot of subtle things that add up - I guess I expected ray tracing to jump out and wow
the 3070 doesn’t struggle and I have all the settings turned up played for an hour didn’t get past 45 degrees
however - the cpu although not hot probably 48-50 degrees was kicking some heat out of the Kraken and the fans were going like the clappers to keep it at that temp
good gameplay and storyline though and good graphics
will have a look at some of the others too. Control is the one I’m saving for next
Man of Honour
23 Mar 2011
West Side
Try the cam software and set a less agressive fan speed and temp curve to sacrifice a few degrees for lower fan speed.
https://nzxt.com/software/cam
OP
13 Sep 2009
Kent, UK
I had it on silent but will tweak a bit more - to be honest the noise is ok was just surprised I was expecting the gpu to be hit more than the cpu.
Played some more and i like it. Playing in the city is different to the type of world in crysis or farcry. Swishy grass etc so took me some time to appreciate the quality.
need to find an rgb controller that works with NZXT, gigabyte, crucial and Kingston
hard to believe there isn’t a common standard! So many software conflicts just to manage lighting
