A
You want them pushing towards the top side of the ceiling to keep it in position.
I would have said A as well, B doesn't look like it'd hold the light in place.
So does the small clips go above the ceiling?
Yes, bend them back on themselves so they are pointing up, when you put the fitting back into the ceiling they will spring back down and hold the fitting up
P.s. nice ninja edit from the first person to reply![]()
so both the short and long clips should clear the depth of the plasterboard ?
Indeed
Didn't realise the clip had been put back on again the other way up![]()
You replied a second before I did with a different answer, I panicked thinking I had it all wrong
Yes.
Watch this from 4 mins.
How'd you rip it out in the first place?![]()
