**THE NVIDIA DRIVERS THREAD**
Caporegime
8 Sep 2006
On Ocuk
All depends if you play any of those games. None of the issues affects anything I play atm.
I did read this regarding Warzone between two people who are obviously disagreeing with each other :p
call of duty black ops cold war - Issue fixed with 496.49
496.13 kills the game its the driver that brings that error period if the game has this or that nobody cares, ppl only care if works and with 496.13 the issue comes up , 496.49 does not
There was no change in 496.49 for the CoD issue, like has been told to you countless times the issue was a randomly occuring shader generation glitch that could happen on any system at any time where a fringe instability or bitflip occurred. all that 496.49 did was result in the shaders rebaking. until Activision resolves the fault on the game client, any time the shaders rebake, its just going to be swapping around people that have the access violation.
16 Jun 2004
Is Nvidia ever to to get around to doing a new, modern control panel?
The current one is just so S---L---O---W and clunky.
How long to populate the list of games, when customising settings!
26 May 2014
I just tried and it took like half a second. The control panel might be ugly, but I've never found it to be slow. Are you using a mechanical drive?
V F
V F
13 Aug 2003
UK
The AMD method looks the business but very sluggy
You'll not remember Catalyst Control Center? (CCC) back in its day. Now that was horrible. It could take 45 seconds to just over a minute to load in the XP days. It wouldn't work without dot Net.
