Google Pixel 6/6 Pro
25 Jun 2007
Downtown
Is there any way of getting rid of the line at the bottom of the screen when using gesture navigation? It's there on pretty much every screen, and I know where to swipe up from so don't need it!
Not on stock android. Change to dark mode on your browser and OS for a better blend.
21 Jul 2005
Officially least sunny location -Ronskistats
Camera updated....phone got hot to the point I got an update that flashlight can't be turned on as device is too hot...
Does it get hot for all you guys ?
I tried out the magic eraser on a few photo's then showed the wife. It was roasting hot after about 5 mins of that lol, so them tensor cores make great winter pocket hand warmer..
28 Sep 2008
Britain
Normal pixel case is good enough. No screen protector. It's not 2007.
Headphones can be grabbed after 14 days and before 65 iirc. Still got one set of unopened 35s from last year's launch. Probably still got a cereal box from the P4 too :D
12 Mar 2008
West sussex
That's strange. I don't think mine warms up at all. Mine is the non-Pro. I'm not sure if Pro has got different thermals or something. Only time I had it hot was during the initial set up.
6 Oct 2004
Southampton, UK
Normal 6 here and only warm when using Waze yesterday for almost 2 hours whilst charging as well. Otherwise I haven't noticed it being warm. Using a Spigen Liquid Air case as well if that makes a difference.
11 Jun 2010
North West Kent
Finally got the EE eSIM working on my pro. Just rescanned the QR code on MyEE and it worked straight away. Just had to do the SIM swap and activated within seconds of entering the PIN EE texted me.
