- 21 Jul 2005
- Officially least sunny location -Ronskistats
Will have better idea myself when I put a screen protector on as I could see that making a difference but so far not that bad!
That's gotta be user error. When you recorded the fingerprint, you gave it good coverage of different angles? It sounds like this is likely the problem, if you place your fingerprint 10 times in the exact same position, then that's the exact position you'll need to use when unlocking.
Not just users. Majority of reviews have said the same. Flossy for e.g. hates his as it's just crap. For me this is the worst thing about the phone right nowIt's either that or there's a batch of dodgy sensors because many of us are finding it absolutely fine and nothing like the car crash other users are experiencing.
For how many years have we been doing FPS now. I would find it hard to believe all of us don't know this already...
Check in app info for uninstall updatesMy rear camera keeps refusing to work and it is saying contact Google. Anybody any ideas before I contact for a replacement?
That's what I'm hoping or there's a hardware problem floating around.. we'll find out soon. I can tell you there's no issue with the way I add my finger print and I've never had problems beforeNot sure if that's happened before on other handsets (imagine it has) but if it is the case, hope a software update would improve it?
My test is a 37 minute video then basically reloading a webpage up to the hour, screen brightness set to to 300 lumens. In an hour, it lost 3% just turning to 4% on the hour.
It's a bit weird.. I've noticed that it has very low aperture and seems to blur everything out in the background. Very odd, even things that I'm trying to keep in focus have blurred out. Strange behaviour and not something I've experienced in my p5 unless I was in portrait mode.I'm not impressed with the camera at the moment. My Pixel 2XL took a great picture every time and everything was in focus. The Pixel 6 seems to be hit and miss. I have taken pictures today of my misses and 2 girls. Every picture has one person out of focus, just slightly but it's enough to ruin the picture. I was using tap to focus and on other pics I was just letting it do its thing.
I don't like not trusting it to take a picture when I wouldn't even think about it with the 2XL.
Hope software can improve it because the bits that are in focus are very detailed indeed so the potential is there.
You explained it so much better than I did lol. But yes, that is what I am finding. It wants to blur everything except what is in the center of the picture. I used to use portrait mode if I wanted any kind of blurring which worked well also on the 2XL. Not tried portrait mode on the 6 yet.It's a bit weird.. I've noticed that it has very low aperture and seems to blur everything out in the background. Very odd, even things that I'm trying to keep in focus have blurred out. Strange behaviour and not something I've experienced in my p5 unless I was in portrait mode.
I think the FPS issue is entirely related to the person
I think I said similar above. I had problems with a OnePlus in screen FPS in the past, when everyone else said it was fine. As it's optical, I wonder if my print just isn't defined enough? The erm, peaks are too similar a colour to the troughs...?
All evening it's been fine though now.
using smart lock in the interim
Android Auto wired connection randomly disconnects and reconnects 7 or 8 times at the start of every journey
