OK I have overdosed on Alderlake benchmarks and you have a variety of choices that are all viable. It seems that DDR5 systems are not really sensible choices at the moment so that does simplify the situation.
Prices are going to be very volatile in the next few weeks and Ryzen prices should drop gradually because they now have actual competition. It looks like Alderlake actually performs better with DDR4 in most games with just a few exceptions showing large performance jumps with DDR5 but they are rare.
The situation is very complex and both Ryzen 5xxx systems and Alderlake with DDR4 will suit your sons needs. I would not consider anything outside of those platforms and advise you to rule out Intel 9/10/11 gen and also earlier Ryzen chips. A Ryzen system is a known quantity so less to worry about but Alderlake does have slightly better performance.
Option 1 -
https://www.overclockers.co.uk/ocuk...x-geforce-rtx-3070ti-gaming-pc-fs-122-og.html
My basket at Overclockers UK:
- 1 x OcUK Gaming Rapier - AMD Ryzen 5600X, GeForce RTX 3070Ti Gaming PC = £1,829.94
- Security Software:**Special Offer** Bullguard Internet Security - Anti-Virus and Security - 1 Year 3 PC
- Operating System:Microsoft Windows 10 Home Advanced - Systems
- Case:*Build Stock* Phanteks Eclipse P400 Air Midi Tower DRGB Case - Black
- Processor:AMD Ryzen 5 5600X Six Core 4.6GHz (Socket AM4) Processor - MPK
- 2.5" SATA Solid State Drive 1:Unwanted
- Storage Drive:Seagate BarraCuda 2TB 7200RPM 256MB Cache Hard Drive - *System Stock*
- Memory:Crucial Ballistix 16GB (2x8GB) DDR4 PC4-28800C16 3600MHz Dual Channel Kit
- 2.5" SATA Solid State Drive 2:Unwanted
- M.2 Solid State Drive 1 (Primary Drive if Selected):WD Black SN750 1TB M.2 2280 NVME PCI-E Gen3 Solid State Drive (WDS100T3X0C)
Total: £1,844.04 (includes shipping: £14.10)
If you go for this option then you can choose any of the cases that you like the look of. You can also choose a 5800x instead of the 5600x that I picked, I picked the 5600x because it is cheaper and would then not be as much of a loss if he wanted a new 3D cache Ryzen chip that will released in 2022. You should ring up when ordering and get them to replace the PSU with a decent 80+ plus gold unit from a more reputable brand.
Option 2 -
https://www.overclockers.co.uk/ocuk...rd-gen-pro-gaming-configurator-fs-01u-tl.html
- 1 x OcUK Tech Labs AMD Ryzen 3rd Gen Pro Gaming Configurator = £2,526.73
- CPU:AMD Ryzen 7 5800X Eight Core 4.7GHz (Socket AM4) Processor - Retail
- Motherboard:MSI MAG X570S Tomahawk MAX WiFi (AMD AM4) DDR4 X570S ATX Motherboard
- CPU Cooler:EK Water Blocks EK-AIO 360 D-RGB All In One CPU Water Cooler - 360mm
- Memory:Corsair Vengeance RGB PRO Black 32GB (2x16GB) 3600MHz AMD Ryzen Tuned DDR4 Memory Dual Kit
- M.2 Solid State Drive 1 (Primary Drive If Selected):WD Black SN750 1TB M.2 2280 NVME PCI-E Gen3 Solid State Drive (WDS100T3X0C)
- M.2 Solid State Drive 2:Unwanted
- Mechanical Hard Drive 1:Seagate BarraCuda 2TB 7200RPM 256MB Cache Hard Drive - *System Stock*
- Mechanical Hard Drive 2:Unwanted
- Power Supply:Corsair RMx Series RM850x 80 PLUS Gold Fully Modular ATX Power Supply
- Soundcard:Unwanted
- Network Adapter:Unwanted
- Case Lighting:Unwanted
- Security Software:Unwanted
- Build Time:Standard Build Systems - Dispatched in approx 10-15 working days
- Gaming Chair:Unwanted
- Gaming Desk:Unwanted
- Cases:Lian-Li PC-O11 Dynamic Midi-Tower - White Window
- Graphics Card:Asus GeForce RTX 3070 Ti TUF OC 8GB GDDR6 PCI-Express Graphics Card
- Headset:Unwanted
- Mouse:Unwanted
- Keyboard:Unwanted
- Speakers:Unwanted
- Monitors:Unwanted
Total: £2,540.83 (includes shipping: £14.10)
This is what I would personally choose for myself if I did not already have a very similar system already. You could swap out the 5800x for 5600x and save some money and choose any case you prefer the look of, I have the Lian Li O11 and it is a lovely case. Lot of options with the configurator. This system has 32gb whilst the others I link only have 16gb , is what I personally use but you can change the other systems to match if you like.
Option 3 -
https://www.overclockers.co.uk/ocuk...orce-rtx-3000-series-gaming-pc-fs-1f1-og.html
- 1 x OcUK Gaming Zirconium Ice - Intel Core i7 12700KF, GeForce RTX 3000 Series Gaming PC = £2,799.95
- Memory:Team Group Night Hawk RGB 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - RGB Black (TF1D4
- Primary M.2 Solid State Drive:Samsung 980 Pro 500GB M.2 2280 PCI-e 4.0 x4 NVMe Solid State Drive
- Secondary M.2 Solid State Drive:Unwanted
- Primary 2.5" Solid State Drive:TeamGroup 1TB Vulcan G SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive
- Processor:Intel Core i7-12700KF 3.60GHz (Alder Lake) Socket LGA1700 Processor - OEM
- Graphics Card:*Build Stock* Asus GeForce RTX 3070 ROG Strix Gaming OC White Edition 8GB GDDR6 Graphics Card
Total: £2,814.05 (includes shipping: £14.10)
Not nearly as many option with this configurator. Is a shame you cannot yet get the 12600K chip in the prebuilds. This is the fastest system from a cpu perspective but it has less choices of gpu so it has a 3070 which is around 10% slower than a 3070ti. Cannot change case and whilst the O11 XL is lovely it is designed for full watercooling set up and is too large for the components it houses in this build, a standard O11 Dynamic would be a better choice for this build but not an option I am afraid.
I have 21 year old son and if I was buying a PC for him I would buy option 1 or 2. I know he is a PC noob and would not know how to troubleshoot the Alderlake system if it had a problem and with it being a whole new architecture there is likely to be issues. I did try to keep the storage options the same as much as i could so the systems were more comparable , can easily change the choices in the configurators.
Hope that all helps. Sorry for wall of text.
