- 1 Sep 2013
What's a worthy upgrade from a r5 3600 as a gpu upgrade is out of the question paired with a 5600xt and 32 gig 3600mhx ram
Cheers
Cheers
Definitely wait. Only a few months away you will get 3d cache CPU. Go at least 8 core and you will be set for a very long time I would imagine.What's a worthy upgrade from a r5 3600 as a gpu upgrade is out of the question paired with a 5600xt and 32 gig 3600mhx ram
Cheers
That is odd if it will be a thing world wide at every store as if they were going to do that they should have a couple of weeks ago as it would have looked much better for them in reviews…*IF* lol
Not gonna post links cause mods might get mad, but a major US retailer today dropped $150usd off the 5800x
5900X is a solid CPU. Prices seem to be going up though.
5900X is overkill, especially for someone coming from a 3600.
5600X is decent but for longevity the 5800X will be the sweet spot; but I'd wait to see what 3D cache looks like.
I don’t think the 5900X is overkill.
Games are barely multithreaded due to complexity and rushed implementations, and that’s unlikely to change in the near future. If you have money to burn then sure, otherwise it’s a waste.
*IF* lol
Not gonna post links cause mods might get mad, but a major US retailer today dropped $150usd off the 5800x, the 5800x is now priced where the 5600x was, as it always should have been
thanks Intel
Depends what games you play and graphics card. Nvidia cards can’t scale well.
What exactly are they scaling? GPUs have a set amount of processing potential, so that's what they output - Nvidia and AMD cards are both pretty even on rasterization so by your logic, all GPUs can't scale well (whatever scaling means).
The only games that use more threads are heavily AI based games like CIV or AOE, and even then, you're not going to get some incredible gameplay uplift with more cores. Like I said, if you have money to burn, go for it, otherwise for any normal high-end gaming, the 5800X is more than enough.
Cheers
