snow forecasted for November, get your CC2's ready !
I have CC +
Not sure if serious….
Kwik fit have their usual Michelin offer on until end of November, as well as Michelin offering cashback from other retailers (not kwik fit ).
I have CC +
If the forecast for snow is true
Not sure if serious….![]()
been told by my step dad, snow is forecasted for about 3rd or 4th week of November
dont know if true or not though
https://www.mirror.co.uk/news/uk-news/uk-weather-forecast-exact-date-25353947
https://www.express.co.uk/news/weat...r-forecast-cold-rain-November-2021-met-office
EDIT: Doesn't help as well I'm finding it hard to find somewhere which has both reasonable priced wheels along the style I'd like and the tyres I want in one package.
I gave up looking for the all-in-one package and bought my wheels from Performance Alloys but as with everything these days there's a 3 to 4 week delay. Once they arrive I'll get the mobile Kwik-Fit out to put the CC2s on. My existing rears are at 3mm right now which is when I usually replace them but I don't want to fit new tyres as the wheels will be going for a refurb early next year.
Are you going to swap back for summer tyres at some point? If not, then Cross Climate seems like the better choice.
Personally I'll be putting the WinterContact on the car at the end of the month because I swap back in March but I've already said my bit about the logic of using all seasons as a purely winter tyre.
Done around 1200 miles on my cross climate 2s and the fronts started at 7mm, they are at either 6.5mm or 6.7mm, will have to have a closer look in the daylight/drier weather than today.
So if it's 6.5mm then I'm looking at 12,000 miles to hit 2mm right? 240miles per the half a mm worn. Or if it's 6.7mm, 20,000 miles?
I'll have a proper look when I'm next off and ger a more accurate mileage, but they don't seem to be wearing very well, unless I'm missing something?
Compound often differs slightly through the wear range (i.e. the last few mm tends to be slightly harder wearing), wear rate will also vary slightly due to the change in circumference (i.e. as the tyre wears the circumference decreases = more revolutions to cover same distance)
Well I got my Goodyear asymtric 5 fitted to the fronts and I'm getting whirring noises, you know like you get on cupped budget summer tyre treads that flange.
Not sure what to do about this, will F1 autocentre swap them for another pair? What's the norm here in this situation?
The pirelli p7 rft they replaced were far better than this. But had advisories for inside edges wearing.
Hmm disappointed after spending this much.
Yeah that's my experience too, ok on baby smooth tarmac, anything else whining/droning in the cabin.Mine make some noise on certain road surfaces. I doubt anyone would replace them for another pair to be honest.
Seem to be mounted ok with the 'outside' label visible.@pallys check that they've put them on the right direction!
