Permabanned
- 23 Apr 2014
- Hertfordshire
Aight, got me convinced. Doesn't take much persuading to get some new kit.
Aight, got me convinced. Doesn't take much persuading to get some new kit.![]()
So, we're hopefully moving house within the next few weeks and our options are either 30mbit BT (FTTP apparently underway, but not about to wait 18 months with crap internet) or up to 1gbit with Virgin... so a fairly clear choice even if Virgin network is full of latency. Expect the best option currently is signing up for a 350/500 offer and then a cheap o2 sim? My other half wants to leave Three due to crap signal so it works out for us to get a sim too.
Some people might not notice the latency issues depending on their usage but I can for gaming since switching from a stable FTTC connection with pretty much a perfectly flat TBB graph. Was worse on the HUB 3 but the likes of FIFA for example, I've had far more latency notifications popping up on screen than I did beforehand as well as speed up lag. I've had issues in other games such as Battlefield as well which weren't as apparent on my previous connection.
If you've been on VM for years then it is what it is and you'll be used to it. I think for those switching from a solid connection in terms of latency, jitter and no packet loss then they could notice some things.
Its entirely area dependant. I've had virgin media in three areas of Cardiff. Two good and one terrible. The latest area, the one I used now (1Gbps) the connection is really good I can't think of any occasion where the latency, jitter or other has caused concern. Whilst I'd agree the VM infrastructure in some ways isn't as good as BT W/S its not night and day difference in a good area.
Not for me, as I said in a previous post I'm in a really good area and I still notice the difference.
I'm not sure how VM could ever compete against sub 7ms latency with next to no jitter in their current state.
Then it seems unlikely you are in a really good area, as others - in seemingly better areas - don't have an issue.
@Rainmaker I am pleased to see your fq_codel results.However, I'm puzzled at your "before", as heavy torrenting should have put 60ms or more of susrained delay on your link. ?
Where are these from?You probably want to look into that, if I was paying for actual Fibre I wouldn't be happy with 7ms.
~$ ping bbc.co.uk
PING bbc.co.uk (151.101.0.81) 56(84) bytes of data.
64 bytes from 151.101.0.81 (151.101.0.81): icmp_seq=1 ttl=56 time=1.44 ms
64 bytes from 151.101.0.81 (151.101.0.81): icmp_seq=2 ttl=56 time=1.43 ms
64 bytes from 151.101.0.81 (151.101.0.81): icmp_seq=3 ttl=56 time=1.42 ms
64 bytes from 151.101.0.81 (151.101.0.81): icmp_seq=4 ttl=56 time=1.41 ms
64 bytes from 151.101.0.81 (151.101.0.81): icmp_seq=5 ttl=56 time=1.41 ms
64 bytes from 151.101.0.81 (151.101.0.81): icmp_seq=6 ttl=56 time=1.43 ms
64 bytes from 151.101.0.81 (151.101.0.81): icmp_seq=7 ttl=56 time=1.43 ms
^C
--- bbc.co.uk ping statistics ---
7 packets transmitted, 7 received, 0% packet loss, time 6008ms
rtt min/avg/max/mdev = 1.411/1.428/1.440/0.041 ms
** edit **
Even from well into mainland Europe I get this:
Yes, absolutely. You need to set up some kind of congestion control algorithm (as I said, fq_codel, cake, bbr) which will lose you a few megs on your up/downstream, but it's worth it. I can hammer my line now and still get almost my original full speed (about 935 megs down and 46 megs up), but my line stays extremely responsive for multiple users. Even when a torrent or other download/upload is going full whack it's almost perfect, especially compared to the mess that was there before I implemented the changes.
Yesterday I updated my Linux ISO collection (actually not a euphemism!) for the month, and had torrents running for almost 24h including seeding back. My BQM for yesterday shows the worst case for me now that I have fq_codel set up. Note that the singular red spike around lunch time was an intentional router reboot for updates:
Uploading torrents is not going to be an accurate speed test!I'm seeding a torrent right now for testing and my upload fluctuate between 20 and 40mbps (I'm on gig1) with over 100 peers connected.
Actually seen it drop as low as 9mbps the other evening again that is on what they call "gigabit" connection.
Pathetic is all I can say....
20-40mbps is the traffic flow in my MikroTik router.Uploading torrents is not going to be an accurate speed test!
[1] but I would say that, being one of the authors of fq_codel & cake that periodically pops up to see how well it is working for people.
It's a pleasure to be speaking with you, thanks for posting. A couple of things I'm not clear on, so it's hard to answer correctly:in "heavy bittorrenting" without fq_codel on the link you should have been seeing at least at least 25ms, more like 60ms over your baseline latency. You didn't show that - so I am assuming you weren't bittorrenting during that test?
