Someone does not even know what 4K resolution is. 4K is 3840x 2160
I also set the game to its preset max settings (4K Ray Tracing Ultra). Even if running at the max resolution of the PS5 for this game (1080p) , a PC would get well over 120fps at the games max preset settings (Ray Tracing Ultra). That's how the devs made the game, probably not the best way to make Cyberpunk2077.
A PS5 is inferior to a PC in terms of raw power, only a fool would argue otherwise.
You complain about the price of a PC, did you expect a High End Gaming PC to be cheaper than a PS5A PC can do a tonne more things than a gaming console.Gaming is just one of those things it can do. So having a higher price is totally reasonable. PS5 games are not cheap, some cost £100.
The problem with pricing is that it became inflated because of Scalpers, Chip shortages, miners,....so PC GPUs have become so expensive...
But without all the scalping, £1,300 could get you a PC with an RTX 3080 and £460 could get you a PS5 . I don't see how that's 6 times more expensive?
Even if you spend £2K on a PC in this climate PS5s are easily selling for £750 so how is that 6 times the price![]()
Does your brain work okay dude?
Spend a minute reading all my posts in this thread. You and poneros keep waffling on about pcs being more powerful. No one in this entire thread had said a PS5 is more powerful than a gaming pc. You keep talking about 3090 spec pcs. So that's where 6x more expensive comes from (£1400 gpu plus a grands worth of additional...I'll take 5x or a touch less if you want to insist on a cheaper spec)
You just seem to keep saying the obvious and arguing against some kind of imaginary viewpoint that no one has expressed.
Let me just get the straight. You seem to keep saying it..
A £1300 pc is more powerful than a £450 console...
A £1400 gpu is more powerful than a £450 console...
A PERSONAL COMPUTER can do more than a GAMES CONSOLE.
Some really amazing revelations from you sarge.
Here's some.
The sun is hot.
Rain is wet.
Grass is green.
Herp derp.
