RTX 3050Ti on Nvidia
2 Jan 2021
It depends on how Intel captures the low end market - but the tech media started ramping up the stories of the RTX 3050Ti for desktop last month
As someone who is actually interested in purchasing the RTX 3050Ti or AMD's equivalent, ive not seen any credible leaks about it on the main nvidia and tech subreddits, Videocardz, Guru3D.
Techreport & Anandtech use to be my goto sites a long, long time ago but my have they both changed drastically now and i'm not talking about the redesigned layouts.Both sites have not been the same since each editor left to work for AMD, Apple respectively.
Besides AMD would also counter with RX 6500 leaks to the RTX 3050Ti leaks if the rumours were remotely true.
The recent leaks are concerned about the 2060 and Super cards.
R3X
R3X
9 Aug 2013
Hopefully Intel & AMD release some budget cards to fill this void, just desperately want 10bit, 4K 120 with full RGB.
2 Jan 2021
RX 6500XT & RX 6400 lol is leaked, i can predict the MSRP and performance roughly on the 6500XT but who knows if it comes equipped with 4GB, 6GB or 8GB VRAM, 4GB is too low in 2021 unless its for e-sports primarily, 6GB should be the minimum standard and 8GB is ideal for going forward for the next few years.
18 Feb 2015
The 4 GB ones are just so that they have a GPU to sell that's above their APUs, but yeah, the situation is dire. The direction of the GPU market however has been clear for years now. Individuals are free to remain in the ecosystem and pay the higher prices, or dip and do something else with their time. Things aren't going to get better until well into 2023.
