- 19 Feb 2007
- Northampton
I take it isn't a founders edition?
KFA2 Hall of Fame edition
I've joined the 3080ti club. Managed to land a Founders Edition - it's installed and I'm not pulling it out for a picture so hopefully this one will do. Oh and you can pull my from the 3070 Owners Thread as I am one no more.
I suppose since I've now built the new pc I can post this
Yes it is isn't it.
Out of interest what are peoples memory temps when gaming and also max boost clock values?
Mine seems be around 83-85 degrees and it's boosting to over 1900, although in bursts. Is that about normal?
Sorry yes it's an FE
I'm pretty sure my 3700x is bottlenecking at 4k, frames are just not where they should be
Shouldn't be, Can you run a games built in benchmark so we can look at the data ?
Assassin's Creed Valhalla is getting between 63 and 65fps.
FarCry 6 is getting around 57 at 4k, Ultra, HD textures and ray tracing.
For some reason farcry 6 is unplayable under 60fps, proper laggy feeling even 1fps under. Doesn't happen with Valhalla.
You need a 16GB card to play FC6 with HD textures pack - anything less runs into problems apparently - AMD sponsored title - FC6 doesnt look any better than FC5 and FC5 also had an HD texture pack. WHack rivatuner overlay on and see what your VRAM usage is.
Played FC6 recently with a 6900XT and honestly in most aspects it looks exactly like FC5 in the image quality department, Based on the visuals it shouldn't need more than 8GB, Nevermind 16GB.
