- 11 Sep 2008
- Stratford-Upon-Avon
Quick question, has anyone had much luck claying without (machine) polishing afterwards?
I've already used fallout and tar remover but the paintwork is still rough and could really do with claying but the majority of forum posts and videos suggest you really shouldn't clay without polishing afterwards (due to marring etc). Was wondering if you can get away with it using a soft clay (was looking at BH) or even a Farecla clay mitt or similar as long as use use plenty of water/clay lube?
I've used a clay mitt gently a couple of times on my car now and never machine polished. Not caused any issues that I can see.
